£198.00 soi en 228€
HiTec Astro Mount Hub Pro V2
The mount Hub Pro is the answer to many observatory or mobile power requirements.
In addition to the below functionality the new Mount Hub pro now also includes a 5 Port USB Hub
In one small neat and tidy unit you can do the following
Control via a PC and the included software
Control & Power Up to 4 Dew Heater Bands
Power CCD Cameras and autoguiders
Power motorised Filter Wheels
Power a Flatfield Panel
Power a Robo Focus or Moonlite Compatible motor focuser and control via the included ASCOM software
Power most popular telescope mounts
Power many other peripheral devices
In manual mode where no PC is necessary you can
Power up to 4 Dew Bands
Power a Robofocus or Moonlite compatible motor focuser with the optional manual hand control
The Mount hub Pro draws it's power from one Mains to 13.8v supply (not supplied) and allows you to neatly and easily power nearly all observatory peripherals.
The MHP is an integrated device consisting of
• 8 Individually selected power outlets.
• 4 Controllable ‘Dew Heater’ Outputs.
• A focus controller capable of driving any unipolar stepper motor based
focuser.
• A USB connection which enables the above to be controlled from any PC
using Windows XP, Windows Vista. Windows 7
A driver has been developed which will allow the focus controller to operate with any ASCOM compliant software such as Maxim DL, CCD Auto Pilot,or the excellent (and free) Focus Max.
